FRAM oil filter system to 1000 Corsa
Started by 1000BC, August 31, 2003, 08:23:36 PM
1000BC
I need a complete assy, base and oil filter frame + parts inside.
Used, little broken ones or new with old style outlook.
Offer!!
Hi,
I can source the later style Carello unit that uses a spin on filter in place of the older drop in filter.  Aside from that it works the same as the earlier Carello unit.
If you look on my website under the Dynamometer Project, you will find a foto there of the unit mounted on the dyna engine frame.  www.scuderiatopolino.com
let me know if this is what you are looking for.
