water tubes
Started by Abarthfan, December 26, 2006, 11:47:30 PM
Multiplas didn't have a front radiator or a water/coolant type heater, did they? . Why would they have water lines inside?
If someone added a front radiator they may have put them inside, but it's a bad idea.
Multiplas do have a front radiator....
small  but its there :)
I guess it makes sense-- with the extra weight and wind resistance I guess they figured the throttle would be floored 100% of the time.
 The small coolant-fed "front radiator" in the Multipla is actually just the interior heater (core) - similar to the heater design used in the Fiat 850.
yes ,because you have a heater in front ,our also int midle of the car and this is back apoof that when you have the tubes under water will be colder
Quote from: guy moerenhout on March 16, 2007, 09:28:31 PM
I always say for road driving its to small ,for circuit its Ok
The car is for road use. But 2 radiators are too much for te A112 water pump to circulate the water. What is the correct dimentions for the front radiator?
Notice that I have an oil cooler too. In that case the radiator I have now is enaugh?
yes ,because you have a heater in your car and tubes are protected
Quote from: ChrisD on March 19, 2007, 09:48:17 AM
The car is for road use. But 2 radiators are too much for the A112 water pump to circulate the water. What is the correct dimensions for the front radiator?
Notice that I have an oil cooler too. In that case the radiator I have now is enough?
An old (1998) Berni Motori catalog I have shows their replica pre-1965 front oil/water radiator is 18x75cm, and their post-1965 front oil/water radiator is 20x78cm. It does not say the thickness of the radiator. There are a few versions available material-wise; copper, 3-row copper or alloy (aluminum). Hope this helps as a starting point? ;)
Thanks JS. I have that catalog too. I have seen the pictures and to tell you the truth I don't belive the radiators are thicker than 40mm. My radiator is custom made. I measured a A112 radiator and desighned mine in order to keep the volum of the radiator as close as possible to the A112 radiator. Considering that the undercar copper tubes help a bit in cooling I hope I will not have any problems. I would just like to know what dimentions other 1000TC owner have as a double check
Hello all,
The water tubes to/from the front radiator need only be slightly larger than the smallest orifice in the water system.  Usually this is the orifice in the thermostat when it is open.  The tubes can be made of either aluminum or copper.  On my race car I use 22mm ID aluminum tubing with AN-16 fittings welded on.  All of the flex lines are AN-16.  I have never had an overheating problem.
I also run only the front radiator with two small fans for slow speed work.  One modification that I made was to replace the small petcock on the top of the front radiator with a small copper line running from there back to the expansion tank in the engine compartment.  This allows the system to self-bleed itself of air, as the expansion tank is the highest point in the system.
The A112 waterpump should be easily able to handle any pumping requirement.  Do not remove the thermostat.  It is there for three reasons.
1. faster engine warm up.
2. restrict flow speed of the water - remember that if the hot water rushes through the radiator it will not have sufficient time to shed the heat.  All you are doing is sending still hot water back to the engine to get even hotter.  Even if  want to remove the thermostat, replace it with a flat plate with a  1/2  to 5/8 hole.
3. The restriction of the thermostat/blanking plate allows the water pump to build slightly more pressure in the down side of the thermostat (in the block/head).  We all know that pressurized water systems can take more temperature before they boil.  Hence raising the pressure in the block will raise the boiling point of water in the block.
BTW - The absolute best conductor of heat is pure water.  The worst conductor of heat is ethelyne glycol (anti-freeze).  The maximum percentage of anti-freeze (should be called anti-boil) should be no more than 25% of system volume.
Hope this helps
