Where to mount a roll bar in a 600 ?
Started by DaveA, January 20, 2007, 11:47:36 PM
Hi
where is the best place to  mount a bolt in roll bar ?
Do the bars get in the way of your head :)
I have been in some other cars and you hit your head (OUCH) on the roll bar  if you are driving on a rough road,
it even had the rubber foam cover on it
Any ideas or pictures /
thanks
dave
The further back you put it the less likely you will hit your head on a bumpy road, but the more likely the roof will collapse and hit your head in a rollover.
Maybe that's why people use cages. He's a link to a sketch for one for a Fiat Punto
http://cgi.ebay.co.uk/OMP-Multipoints-weld-in-ROLL-CAGE-FIAT-PUNTO-MK2-09-99_W0QQitemZ330074630011QQihZ014QQcategoryZ10382QQcmdZViewItem
thanks I saw that , but it really does not show where it mounts to ,
I would think on the back parcel tray where the big bolts come thru would be the strongest place,
but then where for the hoop over your head ?
I think a full cage is more than  I want to do   :)
I do rollcages this way. It is designed for our racing regulations. I think that the main console is more in rear that OMP rollcage for example because i am little bit taller so i dont want to hits to my head. But the main thing is... if you have rollcages in your car you have to use helmet.
Some photos are here : http://ef600.wz.cz
you but mount it  after the ground plate up ,onthe place where normale the rear seat is .With the new seat and when you are +1m80 you dont sit well in a 600 .PS this is same in 500 type body
