why it is important to prevent rear wheel tuck-under
Started by Pantdino, March 20, 2007, 05:22:55 AM
Here is some video of swing-axle cars rolling over when they get sideways on the Nurburgring.  The red 850 Coupe looks like a really nice car.  I also saw a white 850 Coupe and a green 600, both of which did OK.
http://www.liveleak.com/view?i=53a_1174161054
So we use low profile tyres and lower the rear as and get a positive camber angle, right?
Chris,
I think you mean negative camber-- so the top of the tires are closer together than the bottoms.
I suspect the only way to prevent this jacking is with the limiting strap or cable. so the suspension cannot go into positive camber no matter what happens.
I think what happens here is that the driver lifts off the throttle or brakes, which causes the rear of the car to rise. The rear suspension goes into positive camber and that plus the weight transfer away from the rear makes the car start to slide / spin.  The sideways force on the tire pushes it inward, rotating the suspension  arm into even more positive camber until the rear of the car is way up high.  The tire is then so far inward it "trips" the car and it rolls.
If the suspension arm can't rotate down into positive camber the whole process will not start.
Anyone have a different explanation?
Some more information about this video-- I learned about it from the Pantera club forum, where it is mentioned that this corner comes after several much faster ones and is blind.  So these drivers were caught going way too fast into a corner that drops downhill, which of course means you have a lot less grip.
They didn't have much choice but to brake or at least lift off the throttle, which put them into a spin.
Rear-engined cars don't do well in a corner without power on, so it's best to approach any blind corner slowly--brake in a straight line then apply power as you enter the curve.
Yes, I mean negative camber Jim (I always confuse it).
You explaind it well. Plus the downhill corner is a good reason. I do I little drifting with my car but never in corners looking like that.
Do you have any instuctions of how to install a limiting strap? I guess some wellding is required in the swing arm, right?
Hi, Chris,
I haven't seen a diagram or photo of a limiting strap.  Usually the shock absorber is what limits the lower position of the suspension, so my guess is that the BEST way to do it would be to use a shock and spring that are shorter than stock and is at maximum length when the wheel is at 0 degrees camber.
A steel cable or strong leather could be used as a strap with stock springs, but then it would have to be strong enough to hold the spring in compression.  Using a shorter spring would be better, as then the strap would just have to be strong enough to hold the actual weight of the suspension arm, brake, wheel, and tire, which isn't  that much.
I don't know the details of how it's done and what material will be used
Maybe when my car gets here it will have a strap and I can photograph it.
I have seen in a video a 600 raised in the rear with a jac and the swing arm did not drop like it usually does, but it was in 0 camber. I bet the owner had something like that installed but the camera was not close enaught to take a look. I have also seen a covertion to the rear swing arm with the shock absorber located outside the original mounting place and closer to the wheel on the outside of the swing arm. Has anyone seen anything like that? Is it something that Abarth did for better handling?
I managed to find this picture of a swing arm with limit wirecable. There where no pictures of the location that the cable is bolted to the chasis.
Thanks, Chris!
It looks to me like in this case the cable is long enough that the suspension gets some positive camber.  I suppose there's a trade-off between ride quality / suspension travel and safety.
Maybe with shorter springs when having the swing arm in 0 camber you can do the same thing. With a long spring like that in the picture even if you install the wirecable holding the swing arm in 0 camber I don't know how much it will hold because of the spring pushing it to negative camber. So I guess it is all in the spring first and then to the wirecable.
Look at this picture with the relocated shock absorber. Have you seen anything like that before? You think there is any benefit having the absorber there?
Chris,
You are right.  It will take a very strong cable to hold a long spring in compression, so the proper way is to use a shorter, stronger spring.
The different shock is a good way to limit the bottom position of the suspension arm, and you can choose the stiffness and kind of shock you  want as a bonus.
The only problem I see is that the shock and mount seem to stick out from the sheet metal further than the stock shock, so it may hit the tire if you mount a wide wheel and tire.
I will go for the cable myself. This shock absorber seems to be the standard Fiat 600 with removed top cup. I just don't like the idea of mounting custom mounting brackets and prefare the stock ones that are defenatly strong and can take the preasure.
By the way, what is the best rear spring lenght for that job: Keeping the swing arm in 0 camber when the car is parked? 200mm???
Chris,
The photo of the car with the cable arrangement is mine.  This works quite OK, and in this case it did have about 2 degrees of positive camber when fully extended.
The problem with the Fiat type suspension is very similar to what got the Corvair in trouble with Mr. Nader.  The suspension can have a "jacking effect" particularly when subjected to large right-left-right- left motions.  One wheel goes positive, the the car attitude changes and the other side does the same.  In the meantime the suspension on the other side has not settled and the rear roll center keeps getting higher off the ground.  If the car now "catches" on an irregularity in the road or track, over it goes.
One method of limiting swing arm movement is to drill a small hole in the chassis next to the spring mount. (This would end up in the rear seat area next to the coil/shock tower.  Put a straight steel rod with a rubber shock bushing on it  and poke it trough the hole and attach the other end to the trailing arm.  Lengthen or shorten the rod as needed.  As the arm goes up and down the rod simply pushes up and down.
Good luck
Paul,
How long do you make the cable?  I'm thinking it should be just long enough to hold the swing arm in contact with the base of the spring, but not compress the spring. So only the "dead" weight of the parts is being held by the cable.
Is that what you do?  That means you have to have the spring the correct length and not try to compensate with the cable.
Jim,
Unfortunately it does not always work out as you would like.  Many times on order to get the ride height that you want, the spring is actually slighly compressed and tensioning the cable.  I saw what I consider now to be a better way of controlling the arm movement.  Attack a rod (1/4 steel) with spherical rod end to the arm.  Then drill a small hole next to the shock housing and put a rubber bush with a chassis washer and a lock nut.  Now as the suspension moves the rod goes up and down and limits when the rubber bush contacts the chassis.
Alternatively, as I have done since the photos were taken is to replace the standard spring/schock assembly with a "coilover assembly that fits in the standard mounts and itself limits the total travel available.  It also allows infinite adjustment of ride height and spring stiffness.
Carlos
The second picture is too small for me to see well, but the thing looks like a "camber compensator".
It is like an upside down leaf spring that prevents the swing arms from dropping into too much positive camber.
Yes,  these are called a "camber compensator" and are meant to limit camber change, as Jim noted.  They were a popular add-on 30 or so years ago.  I do not believe that Abarth offered them, but I know that Faza (Al Cosentino) used to sell them.  My 1300/124 came with one on it, but I will be removing it because it is non-original.
I have no idea how well these work, and have never heard of one for a 600 based car.   I imagine they would have to affect the handling of the car a bit?
The camber compensator was first developed for use on VWs with swing axles.  It works in such a way that in a left hand turn, with the right rear suspension being in "bound" condition (pushed up into the fender), the compensator would tend to push the left hand side down to keep the tire in contact with the road.  This is the same concept behind the "Z bar" which is a derivation of the stalibizer bar, where the arms at each end go in opposite directions.
The real issue to consider is that in order to make the car handle better you want to limit chassis roll.  If you are successful at this, you will automatically solve much of the rear wheel lift problem.  This process is always started at the front of the car with a heavier stabilizer bar.  If the front chassis roll is reduced to 3-4 degrees, then and only then should attention be paid to the rear suspension.  The first I would do is limit the amount of positive camber that can be generated in a way that adds the least amount of weight to the car. (This eliminates the camber compensator straight away)  Then, once this is done, either by cables, straps, rods  etc., the a rear stabilizer bar should only be added to "fine tune" the overall suspension package.
One note of caution:  When lowering the Fiat 600 be very careful how much shock travel you have left after you lower the car.  If you lower it such that you take up most of the shock absorber travel of the original length shocks, you will have a go kart (been there - done that, although it was many years ago).  This condition of course means that the suspension can no longer absorb ANY chassis roll and you will lift the front wheel (and sometimes the rear wheel) from the ground.  This is very spectacular for spectators.
Hope this helps.
Scuderiatopolino.com
Good luck
Paul, what is the recommended procedure for providing enough travel space for the shocks?  Raise the height of the top of the shock supports?  Or, somehow lower the bottom end?  I had a 600 about 15+ years ago that I lowered several inches, and I raised the top mounting points for the shocks by welding in some steel tubing.  I worked well.  On my current project, I want to be able to retain the stock rear seat though.
What's typically done?
Gil,
Any time that the car is lowered significantly you must be able to recover the lost shock travel.  So if the car is lowered 2 inches (50mm) you have reduced the shock travel by the same amount.
The later TC and TCR cars that had independent front suspension homologated (not the interim ones where an "helper" coilover, mounted in the same location, in conjunction with the standard leaf spring) had the upper shock mount moved as high as possible in the front fender, while still retaining the proper caster.  See the following photos.
For the rear I had custom 20 position adjustable coilovers made that are compact enough to fit in the standard shock location, without altering the chassis.  Secondarily, these also act as the swing arm "limit devices", as I had special provision made for the shock to act in place of a limit strap or cable.
The only thing that you have to be careful of is the adjuster for the rear shock, as it is inside the car (under the rear seat).
Hope this helps with the illustrations.
