As far as the gearbox ratios, the 850TC 4speed close ratios were
3.38 44/13
1.75 35/20
1.20 30/25
1.04 28/27
The five speed simply split some of the gears and could be made with a fifth gear that was slightly over or under drive. The problem with too large an overdrive ratio is that the gear speeds really get up there. At 8500 RPM, if you had a 0.890 fifth gear, the gear would be rotating at 9600 RPM. A good example of this is the Fiat Punto 6speed box where 6th gear is .780. This means at 9000 RPM the gear is doing a very healthy 11500 RPM. This would not last long. Therefore racing gearbox designers always go for a 1:1 final gear, and then adjust for different tracks by changing the lower ratios, or the final drive.
Hope this helps.
