Handbrake
Started by ChrisD, April 16, 2007, 10:27:50 AM
I as many of you I belive have installed Fiat 124 rear diskbrakes. However by doing that the handbrake mounting points are pointing the rear of the car and is hard to install the handbrake cable. I used a longer Fiat 131 (if I remeber correct) cable, but still can't make it to work properly. Is there any kind of solution for this problem? I thought of welding the handbrake attachment points from the stock drums to the 124 mounitng points in a way so that I can use the 600 cable. Or maybe a Hydraylic handbrake convertion would work quite ok. Any suggestions?
Hi Chris, I saw someone who solved this by using a longer cable(s) that did a 180 degree turn so that the stock 124 and 600 parts work.  I have no idea what cable he used, but perhaps a trip to a junkyard might give you some ideas?
BTW, I have been driving around with the copy of the book you wanted, and need to find some time to send it off.....
Hi Gil,
I did the same trick with the 180 degree turn but it does not works as good as I want. That is why I am thinking of the hydraulic solution or somethig else. I am building a new copper tubing system at the moment so I guess i will check on this problem later.
