Does anyone know what size K&N filters fit on a Fiat 124 IDF 124 spider ?
Started by grant gauld, June 18, 2008, 08:11:29 PM
Does anyone know what is the biggest height K&N air filter you can fit on a Fiat 124 spider to suit weber IDF (downdraught) carburettors ? My bonnet has speed 'lumps' like a BS1/CSA not early AS.
Thanks for your input.
  Grant Gauld
webchef reKupnet
Hello Grant,
There is nothing mentioned on the K&N-site for the 124 spider, but you can always measure your carburettor-inlet and the free space you have around.
Then go to this page and find a filter that suits your needs:
http://www.knfilters.com/search/universal.aspx
Let us know what you find!
____abarth gmr-team_____www.Auto-Moto.Link_____
124csa
hello everybody,
i was also thinking about the height of the filters. i used meanwhile two versions: sprintfilter from italy and itg from england, see attached pictures - i think that is the maximum to use without problems with the bonnet. the height of the sprintfilter was 65mm, i think and the height of the itg-filter was 90mm (i can measure it again, when someone is interested).
sebastian
www.fiat124abarth.de
info@fiat124abarth.de
Thanks webchef,i did the same as you did.I was wanting to buy the filters in adavance of fitting the carbs.
Sebastian,Your pics are what i was looking for.I am wanting the tallest K&N filters,naturally.I have read 65 mm was the height and thats where i will start.Guy Crofts book has a pic with K&Ns that look taller.If taller than 65mm is possible i will post my findings.Many thanks,Grant Gauld
