fresh air intake for driver on my replica
Started by Pantdino, March 03, 2009, 06:44:25 AM
My 850TC replica has a race cam, and the exhaust fumes are quite irritating to my nose and throat.
So I have created a way to bring fresh air to my face as I drive.  The side window does not really let fresh air in because the airflow hits the windshield and goes outward away from the window area.  If you put your hand out as you drive you can feel that there is almost no air flow next to the window but it flows very fast just to the side of the windshield.
This system brings this fast-moving, fresh air to my face as I drive.  The aluminum tubing is from a home repair store and the plexiglas air scoop it goes through is from a racing parts supply company.   The air scoop alone does not bring any air in for the reasons discussed above..
Even at 30 miles per hour there is excellent flow to my face.
I belive that Abarths had an air intake for the cabin behind the front emblem with a tube connected under the dash to the air intakes of the windscreen. Why don't you look up a solution like that?
I am pretty sure Chris is correct.  I have seen this part for sale on ebay in Germany before and I think Berni Motori sells them.  I guess you would have to cut a hole through firewall into the passenger compartment though.  Then you could connect up the the window defroster pipes.  Why would a race cam cause more exhaust gas to get into the car and why would it get in at all?
Gil Nicholls
Quote from: zippyfiat on March 04, 2009, 04:44:15 PM
Gil Nicholls
Quote
It wouldn't cause more to get in, but it is much more toxic because of the unburned hydrocarbons present in it.  So it doesn't take much to be irritating.
Yes, I have considered running a line from the grill emblem. But I can't bring myself to cut a hole in the firewall. Also, I would be worried that if the gas tank leaked somehow gas could literally pour right onto my feet.
Sorry-- I messed up the post above and put my response in the purple box somehow.
The other issue is that in I think the amount of air that would come in thru the emblem area would be too small to justify altering the car for. The system I have can be removed in about 3 minutes and leave no trace.
