Hi Paul Vanderheijden from Scuderia Topolino here.
This is precisely the block/crank combination that I use in my race car. I have two of them. It is not difficult to do. 1) you can get a CW cam and distributor drive, or 2) you can put in a gear drive kit and keep the cam and distributor drive that is already in the car.
Another good block crank combination is a 903 block (65mm) with a 1050 crank. Again, two ways to do it. 1) line-bore the block for the larger main bearings, or 2) grind crank for smaller main bearings and have it tuff-trided. I have done it both ways with several customers.
Let me know if you need any or additional help, or visit my website www.scuderiatopolino.com. Take a look at the Forum or look at the technical help section.
