Radiators on Fiat 600
Started by ChrisD, July 12, 2004, 10:38:58 AM
Can anyone tell me how many radiators the Fiat 1000 TCR had?
The original 600 rear mount radiator in case of instalatiion of an Autobianchi A112 engine does it remain in the original place or do I have to remove it?
The front mount radiator is it for water cooling or for oil cooling?
I have also seen a picture of a 600 wich had a radiator under the car in front of the gear-box. All abarths had this radiator?I know that this one is for water cooling but does it work properly under the car?
Please help me, because my car has high temperatures and the weather in my country is pretty hot during summer so I have to find a solution for the cooling problem.
1000BC
Hi Seems that there is a lot of readers but no one knows answer.
Maybe they have a lack of information :wink:
All right for your problem:
Abarth use in first versions a rear radiator + little radiator under the car
This wasn't enough so they moved little radiator to the front under the bumper.
Second version was replace rear radiator with big front radiator. Also there came a little oil cooler to the front too. There is also versions without oli cooler.
In your case if you want to maximice water cooling keep the rear radiator with electric fan and add big front radiator. Oil cooler helps a lot too but I think you don't need to build it in front if you don't race it.
