A112 engine marks HELP PLEASE
Started by smilesoffun, October 05, 2011, 09:18:58 PM
smilesoffun
Hi there,
I have a 1000tc replica which has a A112 engine.
I have been told it is a A112 abarth engine bit not sure if its  70hp
It has a A112 head and 40 Weber with correct bolt on parts
I have read other threads on hear which say about A1 or A2 (A5) markings
But the only marks I can see are the following
A112 AB FIAT on the block
The bloke did buy the new block in 2002 from a VERY well known Abarth dealer in the UK
And has fitted all Abarth springs and valves in the head
Any help would be great
viotti600
#1
You can find the engine type & serial number stamped into the front face of the block, above the timing chain cover & below the distributor.
Jeff Stich
Norco, CA, USA
smilesoffun
Yes thanks have found them
My one is A112 A2 :-)
