Abarth 1300 OT GMR periscope
Started by guy moerenhout, December 02, 2011, 01:46:51 PM
I start now on building back a Abarth 1300 OT Periscope
Have a look and its  for sale to ;Ready our  rolling chassis
front hood fittings  progress
Airflow for front brakes
inner  front wings will be altered to accept the big wheels
a update from today ,it  look so good  that whe  will use it in rally
update  chassis and now in same time thinking on gearbow that goos with the Fiat Twin Cam engine that turns  right.
Normale I wish to adapt a Porsche 911 but mayby you have a better way ?
One suggestion:-
a) a reverse (left hand) rotation Fiat Twincam using a PBS type reverse rotation auxiliary -oil/distributor- drive-shaft
b) an Abarth - or PBS type- 1300/124/850 bellhousing
c) a Bacci type 137 5 speed -dog engagement - 850 based transmission including optional lsd,  or
d) a 5 speed standard 850 synchromesh transmission with overdrive (currently available Italy)
Advantages are:-
no adaptor plates required for engine / transmission connection;
standard 850 clutch and transmission setups including mountings/linkages/ driveshafts etc used; cv driveshaft options available;
several final drive ratios available on item (c) and (d);
Disadvantages are:-
item (a) alteration of twincam auxiliary driveshaft to replace oil pump/distributor gears, both on the auxiliary shaft and at the base of distributor in block (PBS kits no longer available) ;
item (a) is only an option for block mounted distributors (not cam box mounted) and requires an offset inlet manifold (available) to have sidedraft carburettors not foul the block mounted distributor;
item (c) no synchromesh, "dog" engagement;
item (d) robustness unknown
hallo Trevor ,the cluth plate  porsche have the same splin like the Fiat. I have taken +-11 cm from both bellhousings and place the engine togheter with those  two parts .Now I weld this togheter and have a correct new  bellhousing. I dont need to change engine . I fit a distributor lon the rear off exhaust camshaft and use normale intake manifold with the Webers.I will use the
a normale gearbox  ,no L.S our dougbox because I will drive some regularty  rallys with the car no races  so more comfort than heavy work
Another possibility is to turn the 850  gearbox  upside down(? correct)  and change flywheel  to 850.On that moment I need to make a adaptor with T.C engine
Our mayby someone make shaft to let turn the T.C  left ?
Hallo Guy,
PBS used to make an auxiliary shaft to left turn twincams; it used Ford Escort (US) gears no longer available.
I have photos I can post of the minor engineering involved.
It could be done today using a Fiat 242 or 242E distributor (S147P) and one purpose made small gear inserted into the twincam auxiliary shaft, to match the distributor gear.
If no 242/242E distributor available, then the readily available new  S147 distributor can be easily converted.
I will post the photos if I can workout how to post them.
Hello Guy,
Images mentioned in post a few minutes ago.
pbs kit images and Fiat 242 distributor images
wow ,where are friends  for.
Now finding some one that can make the small gear on the auxiliary shaft
#10
update  today ;special shocks  fitting,doors fitted  en rear bonnet on place
karelm
Starting to look nice! Let those pictures coming!
Het gras is altijd groener aan de overkant, want daar hebben ze kunstgras
#12
become to be a  rallycar
Here you can also see the moulding for the frontwindow.This  will be use to make a new one because old one was missing on factory
#13
starting on making place  for fueltank,fitting steering,front airflow from radiator and  front bonnet fittings
Also whe wish to keep a good size wheel like a spare  .So a bit less fueltank must go in.
a update  and now  waiting to build  brakes and  engine gearbox inside
back from paintjob and some painting letter handwork because I wish the old style
with his painting and waiting
Our 5 gearbox :Porsche and  Fiat
#18
gearbox is now  ready . This one you can use in almost all type  from OT  to TCR
