valve clearance and more
Started by Joan31, September 17, 2012, 11:15:10 PM
Joan31
Hello, I would like to know what the valve clearance of a Fiat 131 Abarth, is a competion engine.
I take mounting a distribution belt of 144 teeth x 19mm of width,have you it  more broad?
thank you.
#1
hallo ,when its a competion engine   you must see with camshafts it have
Joan31
Not that kind of leads camshafts, the only information I have is this:Original 16v.Camshaft: Lift 13,0 mm, interverence 5,5mm with spraed angle 105 rad,new bore size, forged pistons, larger diameter valves, 36.5 and 31,5mm, weber carburetors feed 44idf, 190hp-215hp power estimated.
