Fiat Abarth Record Monza "Corsa"
Started by guy moerenhout, May 28, 2013, 03:46:20 PM
a ex Corsa is in and will be back again for race/ rally. The place where it must be
Car is on this moment for sale by owner . Interested ? take contact
luckyRM
I'm sure you'll make a masterpiece of it !
work started
original badges are ok
engine  out
Mayby someone have info about car . Was original red  and ex owner Pinoth (Swiss)
benno
are you going to paint it red again guy?
yes ,client wish to have it back in original color=red
Our whe must find back his race story in yellow/black  noze
one part  from body was coverd by glasfiber
Chassis is  still good and need only some repair in corners
benno
Exellent work, keep the pictures coming Guy
litle by litle,it comes good
some update body  and the  new chassis  for remake zagato seats
new inner skills and rear engine support . I found inside the enginesupport special welding to make it stronger . I did not see this in DB and Monomille   our isit only for race ?
right chassis  ready,the  are 3 compartiments inside to make it strong (under the aluminium
restart after  holydays
#13
in the car was a special Zagato Seat fitted  so whe have made two copys off it . I must say that the sit very good . The back is a bit round ,a normale  Zagato seat was flat and keep you  not so good in corners
#14
left door was very bad. So 50% new  frame build and a new outside skin now fitted
Corners for tray build
The air intakes for front where missing , So whe build  new one  in glasfiber
On car was the gearbox/starter cover in iron changed by a very light glasfiber one (also biggerà
Have this  parts now in programe
some update ,new doorskills  are made,
plexi  windouws with aluminium surrouds are made
Body is ready for ground paint ,so now suspention   fitted on and all  underparts need to go back on
on the route  for epoxy primer
now in epoxypaint
second  ground paint now ready .
