Rally Master Din
Started by Rallybord.eu, April 14, 2014, 07:07:41 PM
Rallybord.eu
The high-quality odometer for the DIN radio slot.
The Rally Master DIN has two counters for the total and the partial route.
It will be quality electro-mechanical counters used with mechanical zero.
The housing of the Rally Master Basic is made ​​of solid steel and matt black coated.
The device is specifically designed for use in the 1DIN slot of many historic vehicles.
Additional features:
System reset
Possibility to connect a computer interface (option when ordering)
Calibration on the front
Small construction
Lighting at the front, can be disabled
Specifications:
Dimensions W / H / D  185/50/90 mm​​(housing, without switch)
Operating voltage12-14 volts
Output voltage sensor 5 volts
Port interface computer
Pulse 10m/Betriebsspannung
www.rallybord.eu
www.car-cover.eu
