Rear Disc Brake
Started by Florian, September 18, 2005, 09:16:09 AM
Florian
Hi All,
Is there any need to install a valve to reduce the brake presure at the rear axle when rear disc brake on a Seat 600 are mounted? I´m thinking of installing the modified part of an A112. Without a minor brake presure at the rear brakes, the pressure would be the same on all four brakes and perhaps it would be too much at the rear ones.
Thanks in advance!
Florian
take form a 124 spider( our lancia) rear and you have no problemes ,pistons are smaller
Florian
Thank you Guy for the recomendation. Very useful, would be very much easier that way!
Florian
