how install oil-cooler?
Started by zdenek76, September 11, 2005, 07:43:41 PM
zdenek76
I'd like to install oil cooler from A112 to my car. Could somebody help me? I prepare 903ccm (GBC block) for my F600D, block is change to clockwise rotation. And also I'd like to use reverse flow oil filter. Thanks for your help.
If you use an A112 water pump, and use an electric fan for the radiator, you can mount the oil cooler in the area where the stock fan/ water pump normally is.  I saw a photo of this just recently, but cannot find it now.
Maybe you want to consider an oil thermostat for the oil cooler setup?  You should be able to adapt one from another make like VW maybe?  The reverse oil flow modification is a good idea I think.  You can add a pressurized center main bearing this way if your engine doesn't have it, and you can drill a small hole in the cam bearing to oil the distributor shaft gear.
I found the photo I was thinking of.  Here is the link:  http://www.race-cars.com/carsales/abarth/1119275274/1119275274pp.htm
Hope this helps.  Not sure how effective the air flow is across the cooler.
