A112 ignition
Started by zippyfiat, November 04, 2005, 05:02:32 PM
I have an Autobianchi A112 electronic/breakerless ignition setup now.  Is a condensor (capacitor) required for this?  How do I connect the wiring to it?  Do I just ground the negative terminal on the coil and connect the + terminal to the ignition "on" circuit?  I don't want to blow anything in this!  Do I just connect the tachometer in the usual manner?
Thanks for any help!
