Abarth / Special cars for sale our wanted by privats => abarth(+others)info, cars and parts wanted and for sale => Topic started by: docspeed on December 14, 2005, 11:16:24 PM
Title: Brake caliper adaptator 124CSA Gp3
Post by: docspeed on December 14, 2005, 11:16:24 PM
Hi,
I own an ex  group3 124 CSA.
I get ATE front aluminium calipers (as fitted on Porsche S) and I'm looking for  the adaptation parts to fix them on drive train.
Is someone get plans or pictures or parts required?
Thank you
Title: Re: Brake caliper adaptator 124CSA Gp3
Post by: guy moerenhout on December 15, 2005, 12:32:04 AM
you need to buy the croma ventilated discs and make a adaptorplate  with the calipter on the car.It go just.There are some photo in forum 124 Polski fiat
Post by: docspeed on December 15, 2005, 10:23:35 PM
Thank you for your quick answer....
I saw the pictures but it doesn't help me completely because I haven't the exact measurements, entrax etc... for perfect fitting.
Do you have a plan with dimensions?
Best regards
Post by: guy moerenhout on December 16, 2005, 08:47:52 AM
sorry  no ,what work on sample
Post by: achy on December 16, 2005, 08:53:00 AM
What calipers ?
There was two kinds of aluminum ATE calipers.
One from Porsche S (disk 256 non ventilated)
Ine from Porsche RS (disk 256 ventilated)
The adaptor plates are more or less similar (different thickness
on bolt side)
Post by: docspeed on December 16, 2005, 09:35:55 PM
I Own the calipers adapted for ventilated discs (around 2cms large).
Post by: achy on December 19, 2005, 10:09:24 AM
If you have THIS cailper then you need the attached mount.
Attached also a photo of original 256mm disk
Regards
Post by: guy moerenhout on December 19, 2005, 01:20:01 PM
hallo ,first :this discis not the normale like from croma etc;;;can you say from with car it is and mayby you can place it on you schanner  and faxit to me .After all how need it I send the fax and the have the good dimentions!!!!!
Post by: achy on December 19, 2005, 03:23:29 PM
Dear Guy
These disks are original 124 Abarth Grp4(see original label) .
I can provide dimensions -if you want-
as well as dimensions of the original adaptor plates.
Post by: guy moerenhout on December 19, 2005, 04:38:54 PM
never to old to learn something ,can you send the correct dimensions please, thanks The problems with old cars is that the same them and didend find the correct ones and that what the find (sometimes it even beter) in this car its beter original because you have more place on wheels
Post by: docspeed on December 19, 2005, 11:41:58 PM
Thank you for all these documents,
as I asked the question , it'll be very kind to give on the web the dimensions of adaptator plate...
Unfortunately, I think that my calipers are from S and not RS  (they were sold like original ones for Gp4...).
Do you think that the solution of Guy (Croma discs ) could be adapted?
Thank you for answer
Post by: docspeed on December 19, 2005, 11:55:44 PM
In fact, as I look to your calipers,
it seems to me that yours are a bit larger than me... Is It the only difference between S and RS types?
Can you give me  the sizes?
Post by: achy on December 20, 2005, 08:59:25 AM
I think I know what type of calipers you have. They are newer version than
the original ones. They have the same bore in the pistons but different
distance between mounting holes
. The must have a slight difference in the weight
also (they are heavier).
Sorry I do not know the type of adaptor plate you need (my adaptors are
for the original).
I am pretty sure that you can adapt the croma disks  playing with the caliper
offset (according to croma disk bell) and you will need a pretty thick spacer
for the rims in order to fit the external piston of the caliper inside the rim.
The Grp4 cars had anyway 20mm aluminium spacers to extend the chassis width.
Guy uses all the time croma disks so I think is more experienced on this.
Post by: docspeed on December 21, 2005, 10:10:37 PM
Hi,
distance between fitting holes: 87,5mm
below: view of the calipers: nearly the same... disformation of pictures perhaps due to close view.
