I started on this car and will make him like you see in the nex topic like a retro racer .Because I have to move the car to new place whe weld in a new floor and will do already some work on the suspention parts
Hi,
can you post some photos of putting the floors in ?
and which floors did you put in ?
original Italian Fiat floors or ???
Thanks
hallo dave ,base for a Allemano Spider 750 is a 1957 fiat 600 .The floorpan is stronger than the newer 600 ;Almost all floorplans that you buy now are remake for the newer so I was taking floorpan from 500.The are stronger and I build back some reforsments on like on the car was in the corners
Hello Guy
Are the Fiat 600 floorpans from Argentina better ?
are there floorpans from Yugoslavia ?
or where do the Fiat 500 floorpans that you used come from?
and what do you need to make the 500 floorpans fit in a 600 ?
Thanks for your help
hallo Dave in the front you must make a litle longer ,come from germany
