abarth cars - community => fiat abarth 750 / 850 and TC => Topic started by: DaveA on May 18, 2008, 07:30:34 PM
Title: maximum stroke that fits in 600 crankcase ?
Post by: DaveA on May 18, 2008, 07:30:34 PM
Hi....
I have a shop that will modify my stock 600 crankshaft for longer stock
they weld one side and offset grind it ,
is this worth doing ?  and what size stroke is best
or is it better to start with a 903 crankshaft  and increase the stock of the 903 crank  ?
Thanks for the info
Title: Re: maximum stroke that fits in 600 crankcase ?
Post by: viotti600 on May 19, 2008, 09:47:04 PM
Quote from: DaveA on May 18, 2008, 07:30:34 PM
  I have a shop that will modify my stock 600 crankshaft for longer stock, they weld one side and offset grind it, is this worth doing ?  and what size stroke is best
  There are several issues to note when stroking the 600 crank (or swapping in a Fiat 850 843cc 63.5mm or 903cc 68mm crank).
The original 633cc 600 block can theoretically take up to a 74mm crank with modifications done to the block for clearance issues (ala Abarth). However, the maximum safe overbore size is 63mm, so piston selection & con rod choice (length & bearing journal size) is a concern depending on the crankshaft being used (the 600 con rods have smaller-diameter crank journals than the later 600D/850/903/etc. con rods).
If using an early 600 (not 600D) block, parts-compatibility dictates that a good choice would be to use the Fiat 850 843cc 63.5mm-stroke crankshaft, the 600D connecting rods, and your choice of Fiat 600 633cc type oversized pistons (generally sized up to 61mm) or Fiat 600D 767cc type standard 62mm pistons (or 600D oversized pistons up to 63mm). While 850 rods would be nice, they require a minimum bore of 64mm for clearance issues. The 600D rods share the same crank journal size as the 850, and CAN be used with under-64mm bores, hence the deferral to the 600D con rods.
Using this combination of parts in the 600 block, you can basically get up to 792cc displacement.
  The 600D engine block has a maximum overbore of 65mm, though the cylinder walls get thin at that size. A good "upgrade" parts combo would be the 850 843cc 63.5mm crank, 850 843cc con rods & 850 817cc 64mm (or 64.?mm oversized) flat-top pistons. With this, you get 817cc-843cc out of a 600D 767cc block.
These upgrades are both done using STANDARD FIAT 600D/850 PARTS. Of course, more cc's could be gained using the longer-stroke 903cc 68mm crank, but pistons &/or rods would have to be custom-made depending on the block used.
A very good page for reference on block/crank/piston/rod use can be found on Mahlon Craft's website at http://users.ntplx.net/~kinukoyc/Pages/tech_pgs/engine_how_to.html
  As for your question about stroking the crankshaft, the 903 crank is your best choice to start with, and can be stroked to 70mm or 74mm quite well. Stroking a 600 55mm crank is really a lost cause when other options are more readily available. ;)
Post by: DaveA on May 19, 2008, 11:55:54 PM
Wow lots of info there,
I would just like to have a little more power and keep the original block because of the serial number matching the tag ,
And my friend can do the  crank work for me
can I put all the 600 D stuff in the early block , crank , rods and pictons if I  machine the bores ?
thanks
Post by: viotti600 on May 20, 2008, 12:43:12 AM
Quote from: DaveA on May 19, 2008, 11:55:54 PM
I would just like to have a little more power and keep the original block because of the serial number matching the tag.
I can completely understand that. ;)
  Yes, the 600D parts will fit in the 600 block with proper machining work done. There are a few other details to handle when doing this, as explained on Mahlon's webpage. The Fiat 600D crank & the 850 843cc/817cc crank share the same size main bearing & con rod journals, but the 850 crank is preferred by most folks due to it's superior strength & counterweight balancing.
Post by: marin on May 21, 2008, 05:44:33 PM
is it possibile to ¨stroke ¨ 903 cc crank to 74 mm???
Post by: viotti600 on May 21, 2008, 10:39:59 PM
Quote from: marin_23 on May 21, 2008, 05:44:33 PM
  Yes, it can be done. 74mm stroke, and it retains the normal 850 (smaller than A112) main bearing journal diameter, so you don't have to align-bore the main bearing saddles on the engine block like if you were installing an A112 crank. Here's a 903 crank 74mm conversion I had done about 9-10 years ago:
Post by: marin on May 21, 2008, 11:43:59 PM
thank you
Post by: Paul vander Heyden on May 13, 2012, 11:03:19 PM
Marin,
The ABSOLUTE largest stroke that you can put in a 903/850 block is 80mm.  I recently did a customer motor that was 68.25mm bore by 80mm stroke.  This will give you approx. 1180cc.  The 80mm stroke crank was a custom forged crank (not inexpensive), but it can be done.
