a ex Corsa is in and will be back again for race/ rally. The place where it must be
Car is on this moment for sale by owner . Interested ? take contact
I'm sure you'll make a masterpiece of it !
work started
original badges are ok
engine out
Mayby someone have info about car . Was original red and ex owner Pinoth (Swiss)
are you going to paint it red again guy?
yes ,client wish to have it back in original color=red
Our whe must find back his race story in yellow/black noze
one part from body was coverd by glasfiber
Chassis is still good and need only some repair in corners
Exellent work, keep the pictures coming Guy
litle by litle,it comes good
some update body and the new chassis for remake zagato seats
new inner skills and rear engine support . I found inside the enginesupport special welding to make it stronger . I did not see this in DB and Monomille our isit only for race ?
right chassis ready,the are 3 compartiments inside to make it strong (under the aluminium
restart after holydays
in the car was a special Zagato Seat fitted so whe have made two copys off it . I must say that the sit very good . The back is a bit round ,a normale Zagato seat was flat and keep you not so good in corners
left door was very bad. So 50% new frame build and a new outside skin now fitted
Corners for tray build
The air intakes for front where missing , So whe build new one in glasfiber
On car was the gearbox/starter cover in iron changed by a very light glasfiber one (also biggerĂ
Have this parts now in programe
some update ,new doorskills are made,
plexi windouws with aluminium surrouds are made
Body is ready for ground paint ,so now suspention fitted on and all underparts need to go back on
on the route for epoxy primer
now in epoxypaint
second ground paint now ready .
