abarth cars - community => 124 fiat abarth rally , group3/4 and 124spider 1600 spider gr3 => Topic started by: 124csa on November 12, 2005, 07:30:24 AM
Title: 124 abarth stainlesssteal exhaust system
Post by: 124csa on November 12, 2005, 07:30:24 AM
hello guys,
i am looking for some 124 abarth drivers, who are interested in to buy a special stainlesssteal exhaust system for their 124 abarth.
the system will only produced, when there are more than 5 customers who order one. by the time i am the only one who has ordered one. the system costs round about 1000 euro + 16%.
here are the technical dates:
Exhaust CSA
The high-grade steel haven exhaust system is copy of the original exhaust system exact in the detail. The pipe diameter is however larger with 51 mm somewhat, in order to come to meet the many uprated Abarths. The high-grade steel exhaust system is fastened also to the original points of hanging up. The suspension at the transmission is included. Also the sound is original. The exhaust system begins at Abarth fan elbow union and fits exactly for the 1.8 l, AC 4000 engine. For vehicles with 2,0 l engine is upward extended the breech piece, in order to avoid a fastening at the tie rod. Break-free bends without diminish cross section. The used high-grade steel is a special alloy for exhaust systems. It is very soft, in order to take up oscillations and toughly enough, in order not to tear. The manufacturer grants on the entire high-grade steel exhaust system 6 years warranty. This plant becomes however only on collective order, i.e. if more than 5 prospective customers are present, built.
if someone of  you is interested in, than you can order it at http://www.gb-motorentechnik.de / info@gb-motorentechnik.de or just post something about the subject here in the forum.
visit http://www.fiat124abarth.de
ciao
sebastian
Title: Re: 124 abarth stainlesssteal exhaust system
Post by: guy moerenhout on November 13, 2005, 04:40:33 PM
I make a gr 4 exhaust systeem that is on pipe till before the rear diff ,than it goos over the axle and back in one rear mufler on the rear with two pipes out .IT lighter and give more power than the original also it a bit higher and most  124 abarths are to low  price for the two parts  770 euro ,when you need a exhaust collector ad 485 euro all  +vat
