dimension of front coil springs
Started by zdenek76, June 13, 2005, 10:58:00 AM
zdenek76
I need dimension of front coil spring for this type od Abarth 850/1000 TC suspension, see http://www.klucka.cz/feder_pic.jpg
If you know, please write me: length of spring, outer diameter od spring, diameter of spring wire and number od spirals. Thanks for your help.
zdenek76
abarth1000TCR
Quote from: zdenek76 on June 13, 2005, 10:58:00 AM
Hi
On my Abarth 1000TCR (1967) the spring was Ø80mm - lenght 200mm - wire 10mm and 200 punds per side.
Best regards ABARTH 1000TCR
How do you install the springs to the shocks??? Is there any kit to do the convertion???
zdenek76
ABARTH 1000TCR: Thanks, that's right. Another man already sent me the dimension. There are my new coil springs.
Klaus Kleber
Hello Zdenek,
have a look on www.vizzamotorsport.de . Mr. Fausto Vizza produces the sets for the coilover frontsuspension.
With best regards
Klaus Kleber
