Quote from: Pantdino on May 19, 2008, 07:19:48 AM
The car seen from the rear I think is a customer's vintage rally car and could very well be a replica.
What do you find incorrect about the car seen from the front? (Yes, it is the one in the video.)
Can you tell what year it is?
Though it's hard to tell much from one photo, I can see that the car shown from the rear has a homemade rear emblem set using the "ABARTH" rear chrome script from the 850TC (which came
after this car), & large individual "750" numbers. The fender emblem looks to be a small Abarth shield, which wasn't used there on early cars. The rear decklid is from a 600D (more louvres). The gauge pod seen in the car is the type used on the 500-based cars (widely available on today's aftermarket scene). The wheels & hubcaps are 13" Fiat 850, not 12" Fiat or Abarth. The roof should also be red, matching the side stripes.
The car seen from the front has the correct Abarth front grille/whiskers & shield/script emblems on the nose. The hood "V" ornament looks to be a reproduction item (slightly different shape/angle/pitch @ front). The rubber hood strap was not normally used until the later 850TC, but most likely added by the owner. Car has original Abarth 7-vent steel wheels, but should have either the Abarth spinner/pie-plate type hubcaps or smaller Fiat 600 Series 1 type hubcaps for this early of a car (the chromed steel hubcaps shown are from later Fiat 600/Abarth 750). The "
Elaborata" fender script is wrong (should be the "
derivazione 750 ABARTH" script that I started this topic about). If I remember correctly from the video clip, the tach unit & speedo unit were not Abarth 750. I now recognize the large blurry emblem I caught a glimpse of on the dash - it's a thick alloy "
Fiat 600" script used on very early 600's (like on my Viotti 600's dash). Again, the roof should also be red to match the side stripes.
The sliding side windows & early style seats (vaguely recalled from video clip) would indicate a 1955 or 1956 vintage.
I find it odd that both of these cars are missing the alloy trim around the rear 1/4 windows. ???
