Gearboxes to suit OT Replica Cars
Started by Rubino, February 03, 2013, 02:58:58 AM
probleme is that sending this  kit to Belguim was  more than kit cost in Australia.
Rubino
Yes Guy, the weight of the adaptor would be as much cost as the gearbox to send! just as same for Porsche box to us here.
SPEED - "The Magnificent Beauty of Mechanised Velocity"
Rubino
Well we did the Vw box to dummy Fiat twincam motor on the weekend, looks good in this position, now to do gearshift so it is not backwards because the VW shift is not as direct as Fiat!
fredabarth
That is looking good, Rubin!!!
Gearshift allready done?
Rubino
Thanks Fred, not done yet, but is understood!
pblake
Hi Rubino. I have a Renault 16 box in my OT 1600 replica. Because of the gearchange mechanism being on the sid of the box I had to use a Hyundai Excel cable gearchange, which works quite well. We made a steel sandwich plate to adapt it to the Fiat engine. Interestingly, the Fiat and Renault clutches are just about identical.
zheka_abarth
Hi all!
Does anybody have experience or knowlage about usage of Alfa boxer gearbox in 850?
I think you  must  turn upside  down  the  gearbox
zheka_abarth
Quote from: guy moerenhout on March 18, 2015, 03:52:36 PM
Interesting idea. Thanks! I'll check how can it work.
chuckcaine
Guy, I saw some photos of yours (I believe) that looked like part of 124 bellhousing welded to front of 901 transmission.How did that work? Chuck
works  very well . We did  already  for cars  like this  and  no  problems
chuckcaine
Thanks Guy,I'm having trouble locating adapter plate so I may have to persue this option. Chuck
keithwwalker
fwiw, I just ordered from Subarugears a reversing gear for a Subaru 6 speed gearbox to fit in VW T3 Doka.
Todd is willing to make engine adapters, but there might be a minimum order to fit a 124 block to the Subaru transaxle.
I will hopefully be getting the gearbox in the next week, so I can post some dimensions once it is here.
Quote from: Rubino on February 03, 2013, 02:58:58 AM
Hello all!
The past couple of months I have been looking at gearbox selection available to complete my OT (berlina) , Guy here I think likes the Porsche 901 series of boxes for the size,ratio's and how many have been used in the past ,also a Fiat 850 box turned upside down as Abarth themselves have done, In Australia we have a short supply of #901 gearboxes and even harder to find in good condidtion, as it is hard finding most parts that are readilly available in Europe!
I have a old (early 1990s) vw gearbox conversion from a previous Fiat twincam to 850 project done here, not happy with most of the conversion, yes it did work but with issues. This forum has been very good for infomation on my project "OT" but with many ways of doing the same job I have to find a way forward with parts easy to find and hopefully in reasonable condition, I have found this on another forum for Fiat group cars, this subaru gearbox shop will sell a reverse crown and pinion set for rear engine vehicles!
http://subarugears.com/
I don't have the knowledge on Subaru gearboxes for strength or ratios, but think they are 30 years younger with parts available here and do know how easy they are to find in any condition !
So far have found these gearboxes used on Fiat 850's - Skoda130, VW type3 (4speed), Porsche 911 early and late(#901) and now Subaru!
I look forward to your thoughts on subaru and any other gearboxes used!
Regards Rubino
keithwwalker
#28
Regarding FIAT motors and transaxles in general:
The 124 series run clockwise, so a reversing gear is required for a fwd transaxle to be used in a rear engine application in addition the differential needs flipping.  With minor grinding, this can be done in a Subaru transaxle.
Subarugears in Australia sells reversing ring and pinion gears.
The 600/850 series run counter-clockwise, so NO reversing gear is required for a front wheel drive transaxle (from a fwd engine that runs CW) used in a rear engine application. But, the ring & pinion will run on the back side (or coast side).
So with 600/850 blocks you can conceptually use any transaxle from a FWD CW engine: Renaults, Citroens, Alfas, Subarus etc., but they will all load the back side of the pinion gear.
Running on the coast side could be a problem, as pinion gears are not designed for that.  The solution, or trick, is to purchase a reversed ring and pinion, but NOT flip the differential.  That way the power goes through the proper side of the gearing.  At least that is the way I understand it.
Again, Subarugears sells reversed R&P's.
Subaru transmissions are strong like the Renault transaxles.  Most are designed for 300HP and at least 225ft-lb of torque.
The only missing link is the engine/transmission adapters..but these can be custom made.
More info here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=503586
Fiat 600  run clock-wise
Fiat  850 runs anticlock- wise
Simca 1000 runs anticlock- wise
