GMR WEBSITE
Abarth Cars
Abarth Parts
Gallery
Contact
Home
Search
Profile
My Messages
Calendar
Members
Logout
Login
Admin
Home
Search
Calendar
October 23, 2026, 10:49:19 AM
abarth cars - community
fiat abarth OT 850 -> 2000
Fiat Abarth 1600 OT Berlina remake Fred Winkel
Started by guy moerenhout, March 18, 2012, 11:01:34 AM
Previous topic
Next topic
Print
Go Down
Pages
1
5
6
7
8
9
10
11
12
13
15
User actions
fredabarth
2000 cc
500
Logged
Re: Fiat Abarth 1600 OT Berlina remake Fred Winkel
#120
March 28, 2014, 11:49:28 AM
And more
toonhyper
1800 cc
Fiat Fever!
Logged
#121
April 04, 2014, 04:58:09 PM
Last Edit
: April 04, 2014, 04:58:40 PM by toonhyper
You can make a whole car Fred! Nice Ha Ha. ;-)
I am Toon, Toonhyper.
Not just a buyer, I am a hunter..
fredabarth
2000 cc
500
Logged
#122
April 05, 2014, 08:12:53 PM
Thank you Toon. I try to make one!!!hahhahahaha.
And some news about the engine. Not great news, because after fitting in the crankshaft an de pistons the block was not straight.
The formel owner machined the block, but with a difference of 0,15mm between the 1st and the 4th cilinder.
So everything out and the block will be machined again in my friends workshop.
fredabarth
2000 cc
500
Logged
#123
April 05, 2014, 08:29:37 PM
Meanwhile I'm busy with the cilinderhead number 2. The original one was also machined, but also the valve were done!!??
And the intake was allready done and not fitting oké with my intake manifold.
I have another one and that one I'm going to use. Only one valve guide is broken, so I will replace al valve guides.
I also machined the cilinderhead because there are casting problems in the watercooling system. I cut them away so the water can go better into the cilinderhead.
After blasting(glass) the cilinderhead I just start with making the intake of the head fit well to the intake manifold I've got.
fredabarth
2000 cc
500
Logged
#124
April 05, 2014, 08:37:51 PM
Cut away some aluminium and make it smooth with some fine tools
Then the intake manifold and the intake together with the gasket and do it again, until I've got a nice complete intake without any "bumps" or whatever!!
I also took out the valve guide.
fredabarth
2000 cc
500
Logged
#125
April 22, 2014, 09:45:12 PM
The oilpump is ready and allready installed. Some modifications at the pick-up. Made the small opening a bit wider.
The plate were the gears are leaning on was a bit worn out, but with a diamond sanding block it all went well to make it smooth again.
fredabarth
2000 cc
500
Logged
#126
April 22, 2014, 09:53:51 PM
Made from the old original timing gears, ajustable timing gears.
fredabarth
2000 cc
500
Logged
#127
April 23, 2014, 11:41:18 AM
Herewith some live-action!!
https://www.youtube.com/watch?v=8AuowrDzuBQ
fredabarth
2000 cc
500
Logged
#128
April 23, 2014, 10:17:57 PM
Also futher with the cilinderhead. After doing the seats with the B&D the seat must work after with some other tools.
All kinds of mills to make the 3 different angles in the intake seat. These angles are 30 degrees, 45 degrees and 70 degrees!
The valves are all fit in perfectly and the cilinderhead is also straight after a treatment on the millingmachine.
fredabarth
2000 cc
500
Logged
#129
April 23, 2014, 10:32:52 PM
By using other camshafts I needed to machine the camshafthousing so after this the new camshaft can attack the valves in full order!!!
slim4936
1800 cc
Logged
#130
April 23, 2014, 11:33:46 PM
Hi Fred,
Did you ever consider the 16v head for more power? Original Abarth engines were quite powerful!
Thanks for the posts (and Maiden!)
Toby
fredabarth
2000 cc
500
Logged
#131
April 25, 2014, 11:42:48 AM
Hello Toby,
Yes, I've thought about it, but first I want build this engine and maybe in the near future a 16v cilinderhead.
Hopefully I will get around 150bhp out of this engine.
Next month there will be two new "maiden"!!
Groet,
Fred
fredabarth
2000 cc
500
Logged
#132
May 04, 2014, 09:21:00 AM
With the dry-build there are some other things that needed a good solution. The original mounting of the dynamo was to high so I needed another mounting bracket. These engines are being used in a lot of other Fiat models. The solution was the bracket of the Fiat 124 spider. Now the dynamo is much lower so I don't have a problem with the weber carbs.
fredabarth
2000 cc
500
Logged
#133
May 04, 2014, 09:38:10 AM
In the meantime also made the steeringwheel. When I visit Engelbert Moell in 2009 I saw some steeringwheels at his museum.
There was also a Nardi wheel that was used in an Abarth. So I bought a Nardi wheel and found a horn with Abarth emblem at Ebay.
But they didn't fit. I had to make an adapter that fit on the Nardi wheel and were the horn also fit in.
Some machining and it fit.
fredabarth
2000 cc
500
Logged
#134
May 04, 2014, 04:55:56 PM
Oh, and the tyres are here for the OT. Original Dunlop racings, 4.50 x 13 front and 5.25 x 13 rear.
Print
Go Up
Pages
1
5
6
7
8
9
10
11
12
13
15
User actions
User actions
Print
